Help!! .....Gen1 brat front rotor rubbing
Thank You Brian....(subarujunkie) for bringing me out the cone washer!!
after replacing with all new front end parts
i tighten the axle and its causes the rotor to rub the brake pad hanger
any ideas?
Thanks for your help!!
Just a basic question, but are you sure it is not the slight, but normal brake pad drag? What I mean is that the brake rotor does not rotate freely, but touches the pads slightly. Welder may be spot on with the spacer point as well.
well after looking at my other brat i notice that the new rotors are 1/8" thicker....grrrrr:mad:
this is causing the rotor to hit the brake pad hanger and stops the rotor from spinning
anyone have this issue or seen this problem with the older gens?
