zydecobro Posted May 18, 2009 Share Posted May 18, 2009 (edited) '88 Soob GL-10 4" lift REAR SHOCK PROBLEM SOLVED, fully adjustable rear suspension. In my pics you ll notice that I have them adjusted most of the way out still have about an 1" to go, after installation I probably could drop it another 1" but if the car is fully loaded that will level it out total cost 75.00 plus shipping what you get is in the pics everything an no mods just install an enjoy, I did install mine on KYB gas adjust shocks, they will work on your stock shocks also you car will handle much better heres a link to look at pics of my installation and yes the kit does come with spanner wrinches of course I think installing longer coil would be better but for a cheap kit you could later go out an put 87 honda front coils cut them down and install so far this set up is working for me just fine http://www2.snapfish.com/slideshow/AlbumID=708279008/PictureID=22957554008/a=78914041_78914041[/color Edited May 18, 2009 by zydecobro Link to comment Share on other sites More sharing options...
Numbchux Posted May 18, 2009 Share Posted May 18, 2009 generic coilover sleeves are hardly fully adjustable. they're a good option, but really only ideal for slamming a car. most of them are faaaaar to stiff to yield good performance results on anything but a perfectly flat course. and shocks stiff enough to accompany them don't really exist for older subarus. Link to comment Share on other sites More sharing options...
zydecobro Posted May 18, 2009 Author Share Posted May 18, 2009 huh, this set is working awesome, 4" lift fully loaded no squating and no absolutely no bottoming out, Im happy just thought i would share with everyone here, also my load on the gl is three mtbikes a kayak and camping gear then a 300mile drive to the lake cant complain and the ride when not loaded is really not stiff what so ever. someone needs to their homework because ive done mine Link to comment Share on other sites More sharing options...
kingbobdole Posted May 18, 2009 Share Posted May 18, 2009 (edited) zydecobro said: someone needs to their homework because ive done mine :lol::lol::lol::lol::lol::lol: OMG really?! Talking smack at two posts! Awesome! Edited May 18, 2009 by kingbobdole holy huge pic batman Link to comment Share on other sites More sharing options...
Numbchux Posted May 18, 2009 Share Posted May 18, 2009 homework? since you've done yours, what spring rate are those? you may have gotten lucky and gotten a set with a reasonable spring rate, but more than likely, your sidewalls are smoothing out the bumps (I, admittedly, didn't notice that your wagon was lifted......hope you don't do any wheeling that requires full suspension travel.....) I ran generic (said "R1 Racing" on the box....I've not seen anything by that name since) sleeves for about 2 years on my wagon that looked almost identical to the ones you have. 2 were 450 lb/in, and the other 2 were 500. I usually ran the stiffer ones in the rear, but it didn't really make much difference. I ran them on numerous different shock setups, 4-lug, 5-lug, stock subaru rears, monroes, and then on to the miata setup. I finally ditched them when they broke the shock rod on one of my miata shocks. I have been running Ground-Control ones with genuine Eibach springs 250 lb/in in front and 275 in the rear for about a year now. I've been doing nothing but homework over the last couple years trying to find a decent dampening option to go with the springs. finally got an application that works like it should, hope to actually drop the cash on KYB AGXs, so I'll at least have some adjustability. but even then, it'll just be a generic "stiffness" dampening adjustability. a true fully adjustable setup would allow ride height adjustment without effecting spring preload. separate bound and rebound adjustments on the shocks, etc. if you'd done your homework, you would have seen these.....but then, you wouldn't be telling me off. so here are some shots of some of the setups I've experimented with over the last 4 years or so. stock impreza, R1 sleeve, GC8 STi "pink" spring EA82, BE Legacy with this setup, I was constantly bottoming out the stock rear shocks: NA Miata rear, EA82 rear, NA Miata front, BE Legacy rear: R1 sleeve, NA miata rear shock, EA82 upper mount: on the car: too much preload (NB miata front shock with 12" long eibach spring): 12" springs and EA82 shocks (these happen to be Monroes): EA82 rear vs NB Miata front: Ground-control sleeves: mounted on the miata shock in my wagon: 12" eibach springs and KYB GR2s that currently reside in the rear of my XT6: welcome to the site. but be careful who you tell to do their homework EDIT: lol @ the king Link to comment Share on other sites More sharing options...
The Dude Abides Posted May 18, 2009 Share Posted May 18, 2009 (edited) :eek:uhhh zydecobro you just talked suspension smack with the frickin suspension master. All those pictures he posted, no joke. Thank you for your advise on the adjustable coilover suspension but be cautious as to who you rut up with. Welcome to the Board. Ben Edited May 18, 2009 by The Dude Abides Link to comment Share on other sites More sharing options...
zydecobro Posted May 18, 2009 Author Share Posted May 18, 2009 damn, I just got b*tch slapped, but really my setup is working, before I had just the stock springs an they were way to soft although I would like to get longer progressive spring set up for the back Link to comment Share on other sites More sharing options...
GeneralDisorder Posted May 18, 2009 Share Posted May 18, 2009 Stiff suspension is bad for lifted Subarus..... mmkay? GD Link to comment Share on other sites More sharing options...
zydecobro Posted May 18, 2009 Author Share Posted May 18, 2009 im sure at one time someone said lifting a soob is not good either, so please elaborate... Link to comment Share on other sites More sharing options...
The Dude Abides Posted May 18, 2009 Share Posted May 18, 2009 Also look at the little sentence under GeneralDisorders name at the top of his posts. Thats not a typo. Again Welcome:) Link to comment Share on other sites More sharing options...
Numbchux Posted May 18, 2009 Share Posted May 18, 2009 zydecobro said: im sure at one time someone said lifting a soob is not goodeither, so please elaborate... not necessarily bad. but defeats the purpose. it drastically limited what little suspension travel there is, and therefore greatly reduce the offroad capability. the only upside would be that you can haul more stuff without squishing the suspension. but you'll still squish the car. it isn't a truck. it won't hold up to hauling real heavy loads for very long. Link to comment Share on other sites More sharing options...
Turbone Posted May 18, 2009 Share Posted May 18, 2009 zydecobro said: im sure at one time someone said lifting a soob is not goodeither, so please elaborate... Without articulation, the rig will just tip over. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted May 19, 2009 Share Posted May 19, 2009 (edited) zydecobro said: im sure at one time someone said lifting a soob is not goodeither, so please elaborate... I don't really care to elaborate. You don't seem to be here to learn - rather you have come here to show off and argue. No one is impressed and your attitude will not engender my experience. My time is too valuable. As for adjustable suspentions - I have a friend that put air shocks from a camaro on his 5" lifted hatch..... 5 years ago. There is nothing new about this. (hat's off to Chux though as he pioneered the non-lifted EA82 suspension research). GD Edited May 19, 2009 by GeneralDisorder Link to comment Share on other sites More sharing options...
zydecobro Posted May 19, 2009 Author Share Posted May 19, 2009 ahh, it articulates. I didnt put bricks on the damn thing not to mention I also am changing to longer coil 12" 325lbs an yes I know its not a discovery of mine I just wanted to share my rear suspension pictures for those who are looking for adjustablility not just pop in honda coils that are too stiff and set to high with out any adjustment so thank you a$$ for interest Link to comment Share on other sites More sharing options...
The Dude Abides Posted May 19, 2009 Share Posted May 19, 2009 :-\ Link to comment Share on other sites More sharing options...
arniejay Posted May 19, 2009 Share Posted May 19, 2009 GeneralDisorder said: I don't really care to elaborate. You don't seem to be here to learn - rather you have come here to show off and argue. No one is impressed and your attitude will not engender my experience. My time is too valuable. GD if its so valuable than why do u post so much? Link to comment Share on other sites More sharing options...
The Dude Abides Posted May 19, 2009 Share Posted May 19, 2009 Link to comment Share on other sites More sharing options...
zstalker Posted May 21, 2009 Share Posted May 21, 2009 hey numbchux, as for the top strut mount in the rear, did you fabricate a new plate to mount to? I can't imagine that being terribly hard, just some cutting/welding/fitting, etc. also, did you remove the torsion beam from the rear crossmember to let the car solely sit on the struts? I'm intending to make my '84 GL-10 Coupe into more of a street-driven race-type car, so this is a really cool setup. ~Erik~ Link to comment Share on other sites More sharing options...
Numbchux Posted May 22, 2009 Share Posted May 22, 2009 it's using the stock upper shock bracket. Ea82s don't have a torsion bar. Link to comment Share on other sites More sharing options...
zstalker Posted May 26, 2009 Share Posted May 26, 2009 oh, ok...I guess I'm just too used to EA81 rear suspension...it's all I've directly dealt with so far. I'll have to see if some of those parts can be retro-fitted to an EA81. ~Erik~ Link to comment Share on other sites More sharing options...
Twitch de la Brat Posted May 26, 2009 Share Posted May 26, 2009 arniejay said: if its so valuable than why do u post so much? Bad move dude. I've semi-butted heads with GD, and you don't want to do a full boar attack on him. You're currently doing a reeeeeeaally good job of pissing him off. I suggest you change course soon, or get your @$$ handed to you on a silver freaking platter. And DON'T try to screw with me. Twitch Link to comment Share on other sites More sharing options...
that one kid Posted March 26, 2014 Share Posted March 26, 2014 Ground-control sleeves:mounted on the miata shock in my wagon:Numbchux,can this set up be adapted to work with a brat and what would need to be done to make it workthanks Link to comment Share on other sites More sharing options...
Numbchux Posted March 28, 2014 Share Posted March 28, 2014 Yes, absolutely. You may want to disable the torsion bar, or lower the spring rate of the coils to compensate. Link to comment Share on other sites More sharing options...
MilesFox Posted March 29, 2014 Share Posted March 29, 2014 Now only if there is an kyb egx2 strut for the rear. ia m fortunate to have the ground control and eibach on mine, but too-tall ea82 2wd struts in back. Link to comment Share on other sites More sharing options...
Numbchux Posted March 30, 2014 Share Posted March 30, 2014 On 3/29/2014 at 10:17 PM, MilesFox said: Now only if there is an kyb egx2 strut for the rear. ia m fortunate to have the ground control and eibach on mine, but too-tall ea82 2wd struts in back. 99-05 Miata rears... Link to comment Share on other sites More sharing options...
