I don't know about the kits, but good grounds are a must for proper operation. I wouldn't consider a kit unless I was having "mysterious" electrical issues. Actually, you can clean up all the grounds yourself without the cost of a kit.
  • 2 weeks later...
"Grouding Kits" are just snake oil. If you believe you are having ground-related electrical problems, your local welding supply shop can help you resolve them for about $12. Go in and ask for some #4 welding lead and copper ring terminals. 2-3 feet to run from engine and transmission, 1 foot or so to run from the body. Bring both of them up directly to the battery. You simply aren't going to get better ground potential than that. If you continue having ground problems, then you need to look at the individual ground points for whatever component is affected.
Ive seen a couple of them....#1 I Will say some of them look really cool!..:grin: But obviously thats not why people them....As others have mentioned If your just getting a grounding kit to sure up the grounds Personally I would just go around and clean/tighten all your ground connections...Any specific problems your experiencing?
