aa8jzdial Posted May 19, 2009 Share Posted May 19, 2009 99 Legacy Intermittent Speedo. I am recommending to friend to put voltmeter across the gauge. When it stops working, read the handheld voltmeter monitoring the drive signal. Good readings on the hand held, head is kapput. Good Idea? Is the signal millivolts, milliamps, volts or btu's per psi? thanks rick w mi Quote Link to comment Share on other sites More sharing options...
Legacy777 Posted May 19, 2009 Share Posted May 19, 2009 Should be volts. Quote Link to comment Share on other sites More sharing options...
ron917 Posted May 19, 2009 Share Posted May 19, 2009 If you're going to go that far, just fix it. The speedo in my son's '99 Outback went intermittent. After living with it for almost a year, he took it out and re-flowed every solder connection he could find on the speedometer head. Some looked questionable, but he did them all. It's been good for 2,000 miles now. Quote Link to comment Share on other sites More sharing options...
porcupine73 Posted May 20, 2009 Share Posted May 20, 2009 '99 Legacy speedo heads are known to have this issue. Quote Link to comment Share on other sites More sharing options...
