The crush type drain plug washers that are generally used aren't readily available around here.
Is there any problem using those flat ones instead? Leakage, for example.
well i think you run the risk over having to over torque it to prevent leaking potentially damaging the threads. but in general it should be OK.
you can order them online from the dealership, though you'll pay more in shipping than you do for the washers.
what's your location? no dealership near by?
axel,
you need to go into "user cp" tab above and change your settings so you can receive private messages. or send me a private message with other contact info.
i have the washers you want.
thanks,
john
