Cant get alignment into spec due to old suspension?
It's possible if the bushings are shot and/or the strut spring rate has changed. Replacing all the rubber bushings (control arm and strut top at least) and verifying the spring dimension on the strut should restore it and make adjustment possible again.
It's also possible that something is bent - it can be difficult to tell without dismounting each component from the car. "old" could mean wore out rubber or it could mean bent....or both. But his statement is likely true for some very real reasons.
I would say rip into it and inspect as you go. Replace as needed. Align after.
Its possible that the strut could be bent..... did he even look at it though? I have bent strut tubes but it takes some serious air unless you hit something. Generally if you hit something the control arm will bend before the strut will. Only way to bend a strut by itself is to get a couple feet of air.... in my experience.
when i asked him why he couldnt get it into spec his response was "old suspension" and the recommended fix was "camber kit"... if the root cause is old suspension, wouldnt' changing the worn suspension components be the logical next step? camber kit? ....
