bsaride Posted May 24, 2009 Share Posted May 24, 2009 OK, at the beginning of the year I lost 4th gear when I slammed a pothole pretty good. Inspection showed the shift linkages looked fine. Did find a bad tranny mount and just had time to replace it (finally). I still don't have 4th, can select when stopped, grind syncro when moving. Any ideas where my problem is? 1996 Legacy Wagon 2.2? 5 speed Jay Link to comment Share on other sites More sharing options...
Legacy777 Posted May 25, 2009 Share Posted May 25, 2009 Probably something broke inside the transmission with the shifter fork. Not much you can do about it unless you open the transmission up. Link to comment Share on other sites More sharing options...
