WheaT_BeeR_MaN Posted May 26, 2009 Share Posted May 26, 2009 so i been having problems with power to my fuel pump but now i have my fuel pump pumping i get no fuel comming out of the fuel tank. ok so this what i have done. i took off both fuel lines from the tank and no fuel came out. so i decided to put 5 gallons of gas in the tank incase the gauge isnt working. still nothing comming out. so i stuck a oil dip stick in the spout off the tank and only maybe a 1/4 of it was wet. im puzzled. im mean in reality the whole thing should have be been wet and should have started to pour out if there was something was blocking it.theres over 5 gallons of gas in it. what am i suposed to do? is it posible theres still not enough gas in there? also i stuck a hose into filler to make sure gas was there and able to pump. which worked. please help. Quote Link to comment Share on other sites More sharing options...
ivantruckman Posted May 26, 2009 Share Posted May 26, 2009 i had one do that, i tried compressed air to revers the blockage, didnt work however. i ended up replacing the whole tank. Quote Link to comment Share on other sites More sharing options...
WheaT_BeeR_MaN Posted May 26, 2009 Author Share Posted May 26, 2009 that wasnt the reply i was looking for, hehe. so i been reading and a couple people took theres to a radiator shop and had them cleaned out. dang it i just put new gas in it now i have to throw it away. Quote Link to comment Share on other sites More sharing options...
bheinen74 Posted May 26, 2009 Share Posted May 26, 2009 your hose could be kinked, or it could be blocked, gummed up with old gas that has varnished. hope for a kinked line. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted May 27, 2009 Share Posted May 27, 2009 Drain the tank (the bolt on the bottom of the tank). Then remove the fuel level sender (carefully as the studs can break off) and look inside. If it's a mess in there (rust, etc) then just replace the tank. You'll have to pull it to have it cleaned and there's just no reason as there's plenty of good tanks to be had for cheap here in the NW. GD Quote Link to comment Share on other sites More sharing options...
WheaT_BeeR_MaN Posted May 31, 2009 Author Share Posted May 31, 2009 i drained it and it doesnt look that bad in there. what i tried putting carb cleaning down the pickup and it still dosnt flow. i started taking the gas off tank off but relized i need to drop the rear end to get it out. i live in apartments so i cant really do to extreme of work in my parking spot. any other ideas of maybe how to get the pickup to start flowing? Quote Link to comment Share on other sites More sharing options...
Greenley Posted October 8, 2011 Share Posted October 8, 2011 What was the outcome of this issue? Was it resolved? Quote Link to comment Share on other sites More sharing options...
nipper Posted October 9, 2011 Share Posted October 9, 2011 Not around gas ... Quote Link to comment Share on other sites More sharing options...
