hatch clutch... can i change flywheel?-from 8-7/8 to7-7/8 with a 7/8 spline
It isn't - 80 through 82 used the 200mm clutch. 83 through 89 2WD's used the same 200mm clutch.
It's the 83 and newer 4WD's that use the 225mm clutch.
I have told you this - third time now. Call Discount Import Parts in Milwaukie or go to the dealer.
This is not an unusual clutch - hell Autozone can get them easily.
As for the interchangeability - the 200mm and 225mm interchange without issue. You have to use the flywheel, disc and pressure plate for the 200mm. Personally I throw the 200mm's in the trash as they are too small for a 4WD.
