Uberoo Posted May 28, 2009 Share Posted May 28, 2009 I replaced the left front axle in my 84 GL offroad toy.Now it hops when I try to accelerate.Its really bad at lower speeds.At the higher speeds its just more of a bad vibration.I can drive around without pressing the gas and it drives fine,no clicking or binding up,etc but if I want to merge into an intersection..The engine when its doing this sounds like I am flooring it then letting off, repeatedily. Car has 2" suspension lift and 235's.It didnt do the bucking/hopping before Just after I replaced the axle.Axle is a new $60 GCK axle from schucks. Link to comment Share on other sites More sharing options...
Uberoo Posted May 28, 2009 Author Share Posted May 28, 2009 I dont know if it may be related but the carb is running rough(always has) now it likes to stall when stopping) aslo the factory volt gauge is reading 0 volts which isnt really possible... Link to comment Share on other sites More sharing options...
one eye Posted May 28, 2009 Share Posted May 28, 2009 I replaced the left front axle in my 84 GL offroad toy.Now it hops when I try to accelerate.Its really bad at lower speeds.At the higher speeds its just more of a bad vibration.I can drive around without pressing the gas and it drives fine,no clicking or binding up,etc but if I want to merge into an intersection..The engine when its doing this sounds like I am flooring it then letting off, repeatedily. Car has 2" suspension lift and 235's.It didnt do the bucking/hopping before Just after I replaced the axle.Axle is a new $60 GCK axle from schucks. thats because the front tires are like this \ / while you are on the gas, it hops all over the place, if you are to put it in 4wd hi you wont have any trouble and on the feeway you can put it back in 2wd. Jeff Link to comment Share on other sites More sharing options...
Uberoo Posted May 28, 2009 Author Share Posted May 28, 2009 I suppose I will try the 4 hi thing to do straight from red lights/stop signs.As there any tip for when you need turn from a stop?Just go easy on the gas? Link to comment Share on other sites More sharing options...
GeneralDisorder Posted May 28, 2009 Share Posted May 28, 2009 You have a single new axle installed amongst a forest of old, sloppy parts.... the results are often unpredictable in such cases. You may have a bad DOJ, or it could just be tight. Depending on how the new axle feels it may be that you need to replace the other axle and possibly some mounts as well. GD Link to comment Share on other sites More sharing options...
Caboobaroo Posted May 28, 2009 Share Posted May 28, 2009 I've run into a few issues with "new" axles myself but mainly on cars I've 5-lugged. My problem was I was getting axles for pretty cheap from a local supplier to my shop. Turns out the DOJs do not have an actual cage and ball setup but more of a roller bearing setup (3 roller bearings compared to 6 ball bearing/cage setup) and was causing nasty vibrations under accel, decel and cornering sometimes as well. Link to comment Share on other sites More sharing options...
SOOBOUTLAW Posted May 28, 2009 Share Posted May 28, 2009 You should check your lower control arm and tie rod ball joints. I've had a tie rod ball joint pop out on me once. Also recheck your axle torque. Can't hurt. Plus, if your struts are shot, you would likely get alot of wheel hop and loss of traction from a standing start pretty easy. I've had my front tires dribble like a pair of basketballs on bad struts. And plenty of torque steer when accelerating. Link to comment Share on other sites More sharing options...
one eye Posted May 28, 2009 Share Posted May 28, 2009 Mine does the same thing and so do all the others, its just the way of the 2" lift. Jeff Link to comment Share on other sites More sharing options...
Uberoo Posted September 28, 2009 Author Share Posted September 28, 2009 I know this is an old thread,but I just got my toy running again and looking out the window I could see the front tires go from 0 camber to full positive camber when ever I touched the gas. Would limiting straps work while its on the street to control the tires?Must just be the soft springs or something but the front end lifts and the tires just go full positive. Link to comment Share on other sites More sharing options...
