BRAT fuel sender problem, part 2
Ok... took apart the connector behind the right tail light and cleaned it out, and the problem has not changed or gone away: The gauge reads WAY too high. Currently, after having driven 100 miles on the tank, the gauge reads that the tank is 125% full. :-\
Next course of action?
Just so you know;
There's 2 bullet connectors at the sending unit,
the connections behind the RH tail light,
another set of connections behind the front RH panel in the bed,
one more set of connections behind the B pillar trim,
more connections behind the RH kick panel,
then the connection at the dash unit itself.
If it is a shorted wire, you may be able to isolate what section it's in by working your way forward from the sending unit and un-plugging the harness at each point while checking the gauge. When it reads dead empty, you've isolated what section of the harness is shorted.
Sounds good in theory anyways.
http://mshoup.us/docs/fsm/EA81/83/Chapter15-Electrical_System.pdf
page 15-121 has wiring diagram
page 15-123 has troubleshooting guide.
Edited by TomRhere
more info
