ringe Posted January 22, 2004 Share Posted January 22, 2004 I use my car for work, and do a lot of U turns, out of culdesacs and whatnot. The car has begun to shuddle pretty badly when powering through a Uturn, or any other sharp turn under power, and when I let off I hear this aweful grinding of metal on metal. Is this my CV joints going bad, or is something else screwed up like my tierods or something? Thanks in advance. Link to comment Share on other sites More sharing options...
torxxx Posted January 22, 2004 Share Posted January 22, 2004 sounds like wheel bearings to me cvs usually click and pop when you turn sharp when they are going out check the cv's by checking for up and down movement.. grab the shaft from under the car and pull straight down and then push up (on the middle of the shaft) They shouldnt have play going up and down, just side to side Link to comment Share on other sites More sharing options...
ringe Posted January 22, 2004 Author Share Posted January 22, 2004 Ok, thanks for the advice. Is it expensive to replace wheel bearings, and is it necessary? I mean, if I neglect it for a while is there a danger of failure? Link to comment Share on other sites More sharing options...
Setright Posted January 23, 2004 Share Posted January 23, 2004 There is the potential of a bearing getting so hot that it seizes and locks the wheel. This is extreme, and usually preceded by a lot of loud grinding/whirring noises, so keep your ears open, and start planning the bearing swap. Link to comment Share on other sites More sharing options...
rallynutdon Posted January 23, 2004 Share Posted January 23, 2004 Sounds exactly like my situation 3 weeks ago with my 91 Legacy. Came and went sporadically, in a straight line or when turning, no pattern. It was the outter CV joint! Link to comment Share on other sites More sharing options...
ringe Posted January 24, 2004 Author Share Posted January 24, 2004 Quote Originally posted by Setright There is the potential of a bearing getting so hot that it seizes and locks the wheel. This is extreme, and usually preceded by a lot of loud grinding/whirring noises, so keep your ears open, and start planning the bearing swap. The CVs are old anyway. Perhaps I will keep my ears open as suggested and wait until I really need to make the repair. It could wait till this summer. Thanks guys, and take care. Regards, Link to comment Share on other sites More sharing options...
Tolerance02 Posted January 24, 2004 Share Posted January 24, 2004 I'd suggest, jack up the car and see if there is free play on the front wheels. The nut on the end of the drive shaft may be lose or even the lower ball joint may be worn. Link to comment Share on other sites More sharing options...
ringe Posted January 24, 2004 Author Share Posted January 24, 2004 Ok, I'll check that tomorrow. Link to comment Share on other sites More sharing options...
torxxx Posted January 24, 2004 Share Posted January 24, 2004 dangers or bad wheel bearing? you axle could seize up. Add 55 mph to that and you got a flip into the ditch.. jack the car up and pull on the tires. You can usually feel it by doing that if the bearings are going. Wheels bearings arent too expsensive and arent too hard to replace. Not sure on the newer soobs if they have to be pressed out like the ones on my 86 Link to comment Share on other sites More sharing options...
ringe Posted January 27, 2004 Author Share Posted January 27, 2004 Quote Originally posted by torxxx dangers or bad wheel bearing? you axle could seize up. Add 55 mph to that and you got a flip into the ditch.. jack the car up and pull on the tires. You can usually feel it by doing that if the bearings are going. Wheels bearings arent too expsensive and arent too hard to replace. Not sure on the newer soobs if they have to be pressed out like the ones on my 86 I will have the front end inspected soon anyway. Thanks! Link to comment Share on other sites More sharing options...
