jbain8 Posted May 30, 2009 Share Posted May 30, 2009 Hello everyone, I've been doing some offroading with my D/R buggy and now I feel I want to add a Nissan TCase for gearing and an automatic for crawling. My question is will the 3spd pushbutton single range auto's of the mid to late 80's handle 26in tires and a 1200 pound buggy? Thanks in advance Link to comment Share on other sites More sharing options...
Twitch de la Brat Posted May 30, 2009 Share Posted May 30, 2009 With the weight reduction of a buggy, it may be able to handle the 26 tires. I would look into an early 4EAT though. It'll give you a better gearing ratio and stronger gearing, seeing that it was designed to push around a bigger car than an GL's. Just find one in the jy that's wrecked, no beautiful bodies to pull from. Chances are the nice ones have an issue. Idk if the 4EAT came in a selectable 4wd for though... Just keep checking, I'm sure you'll find something that suits your needs. Twitch Link to comment Share on other sites More sharing options...
monstaru Posted May 30, 2009 Share Posted May 30, 2009 the 3eat will not stand up.like stated, the 4eat would, but it would need to be gone through i would think.they do make a selectable auto switch set(allows you too run your auto like a manual if need be) i am looking into a similiar option for my rig.so i can teach the kids to drive. i would look into the samurai transfer case as the low gear sets are wAy cheaper , and lower than the nissan options.cheers, brian Link to comment Share on other sites More sharing options...
The Beast I Drive Posted May 31, 2009 Share Posted May 31, 2009 Get a 4eat like stated, then weld the center diff so it wont burn up being used rwd all the time, then it should be able to handle it, I think Outbacks came with 27" tires factory? So it should be fine Oh and since you'd then have the divorced front diff, drop in some 4.11 or 4.44 gears for better crawling power -Bill Link to comment Share on other sites More sharing options...
Gloyale Posted June 3, 2009 Share Posted June 3, 2009 Get a 4eat like stated, then weld the center diff so it wont burn up being used rwd all the time, -Bill There is no differential in a 4EAT. It is a hydraulic clutch pack. It may be hard to weld because of the layers of plates with friction material in them. Also, If this is going behind a EA82, he will need a later XT or a GL turbo/RX with 4EAT, or at very least the bellhousing/front diff section from one to use on an EJ 4EAT . And then there is the matter of the TCU. It will want signals from the TPS of the donor car. It may work without that signal, but will have a hard time deciding when to shift. Honestly, If you are going to a T-case, you might as well make an adapter to use a RWD automatic from a Sidekick, 4cyl. Ford ranger, or other small RWD truck Link to comment Share on other sites More sharing options...
