4x4_Welder Posted May 31, 2009 Share Posted May 31, 2009 I've diagnosed a problem as the #2 injector is leaking. I am planning to throw another used injector in there, but I'd also like to change the o-rings on it. Do I have to get those from Subaru, or are they a standard o-ring? Quote Link to comment Share on other sites More sharing options...
EVOthis Posted June 1, 2009 Share Posted June 1, 2009 Personally I wouldn't feel comfortable getting the o-rings somewhere else even if you can closely match them up...Personally I view these as a "dealer only" item...The last thing you want obviously is that other injector leaking.... Quote Link to comment Share on other sites More sharing options...
hankosolder2 Posted June 1, 2009 Share Posted June 1, 2009 +1. The o-rings have to be gasoline/solvent resistant. I had an injector o-ring failure (on the fuel rail side) on a Honda and it produced a large stream of gas all over my hot engine. Not cool. Nathan Quote Link to comment Share on other sites More sharing options...
4x4_Welder Posted June 1, 2009 Author Share Posted June 1, 2009 Dealer quoted me $160 for all o-rings. Not gonna happen, no way no how. I'm going to get a nitrile o-ring kit and do it myself. I have done some research, and nitrile/HNBR is the correct material to use. Quote Link to comment Share on other sites More sharing options...
johnceggleston Posted June 1, 2009 Share Posted June 1, 2009 was that an online price qoute? Quote Link to comment Share on other sites More sharing options...
porcupine73 Posted June 2, 2009 Share Posted June 2, 2009 Personally I would go with the genuine o-rings from Subaru. Only for this reason, I had my injectors serviced by Witch Hunter some years back, and on some of the injectors I used the o-rings WH sent, and on some I used new genuine rings. They looked the same to me, but the o-rings sent by WH leaked air and I had a sucking sound around those injectors. If your local dealer is ripping you off find a Subaru dealer selling parts online. Quote Link to comment Share on other sites More sharing options...
