brompy Posted January 23, 2004 Share Posted January 23, 2004 found the leak on my head gasket at the rear of the driver side head......last head bolt on the bottem was loose.....it just happens to be at a spot that can not be seen because of the engine mount crossmember......and the smell is sickening when it gets sucked in.....good luck Link to comment Share on other sites More sharing options...
Alan Phillips Posted January 23, 2004 Share Posted January 23, 2004 You found a head bolt loose? What did you do to determine that? I am hoping the dealership will have to take care of it. I have smelled the coolant, but not until recently did I finally find it! Drivers side towards fire wall right above the exhaust. Explaining the smell. Let me know what you did? Thanks! Link to comment Share on other sites More sharing options...
forester2002s Posted January 23, 2004 Share Posted January 23, 2004 Are you sure that it was a head-bolt that is loose? I thought that the head-bolts were hidden inside the rocker-cover (which has its own mounting bolts). Link to comment Share on other sites More sharing options...
Legacy777 Posted January 23, 2004 Share Posted January 23, 2004 please keep all replies in your other thread. Link to comment Share on other sites More sharing options...
