So I have my 02 Outback fresh from having the heater core replaced and now the A/C is acting up. Sometimes while running the A/C (which seems to be cooling fine) and then after I cut the car off it sounds like a horn is going off (emitting a tone) in the engine. It will last from 5 to 20 seconds after the car is off. Any ideas?
Thanks!
Foghorn a/c related sound is often the metering/expansion valve at the evaporator.
If that is the case what is the best way to have that fixed? And what level of expense are we talking about?
