shaner Posted June 2, 2009 Share Posted June 2, 2009 So I have my 02 Outback fresh from having the heater core replaced and now the A/C is acting up. Sometimes while running the A/C (which seems to be cooling fine) and then after I cut the car off it sounds like a horn is going off (emitting a tone) in the engine. It will last from 5 to 20 seconds after the car is off. Any ideas? Thanks! Quote Link to comment Share on other sites More sharing options...
Legacy777 Posted June 2, 2009 Share Posted June 2, 2009 Can you pinpoint where the noise is coming from? Sometimes you can have pressure leak by from the high side to low side, but that is typically more of a hissing sound. Quote Link to comment Share on other sites More sharing options...
mdjdc Posted June 2, 2009 Share Posted June 2, 2009 What you are hearing is the high pressure gasses going thru the orifice tube in the system. Have it checked out, but it is probably nothing to worry about. Quote Link to comment Share on other sites More sharing options...
porcupine73 Posted June 2, 2009 Share Posted June 2, 2009 Foghorn a/c related sound is often the metering/expansion valve at the evaporator. Quote Link to comment Share on other sites More sharing options...
shaner Posted June 2, 2009 Author Share Posted June 2, 2009 Foghorn a/c related sound is often the metering/expansion valve at the evaporator. If that is the case what is the best way to have that fixed? And what level of expense are we talking about? Quote Link to comment Share on other sites More sharing options...
