brighton98 Posted June 2, 2009 Share Posted June 2, 2009 I'm trying to tighten 98 Lego's A/C belt, but the nut at the end of the slider bolt is cracked, so I can't get adjustment. Any tips--also, does Subaru sell the sliders (none at J/Y)?? Thanks. Quote Link to comment Share on other sites More sharing options...
Rooster2 Posted June 2, 2009 Share Posted June 2, 2009 I had to replace the slider. Got mine from a J/Y. Don't know if Dealer stocks the item, but prolly could order you one. Suggest you call other junk yards, if not too far from where you live. Any Leggy with 2.5 Gen 1 motor from years 97-99 will work. Maybe even a slider/bolt from a 2.2 or Gen 2 on the 2.5. Another thought is to go to any hardware store with the bad bolt/nut in hand. I know from going to an Ace Hardware store, that they have a wide selection of bolts and nuts in both metric and SAE sizes in stock. You should be able to find a replacement there. Quote Link to comment Share on other sites More sharing options...
