Adjusting A/C belt--slider bolt cracked
I had to replace the slider. Got mine from a J/Y. Don't know if Dealer stocks the item, but prolly could order you one.
Suggest you call other junk yards, if not too far from where you live. Any Leggy with 2.5 Gen 1 motor from years 97-99 will work. Maybe even a slider/bolt from a 2.2 or Gen 2 on the 2.5.
Another thought is to go to any hardware store with the bad bolt/nut in hand. I know from going to an Ace Hardware store, that they have a wide selection of bolts and nuts in both metric and SAE sizes in stock. You should be able to find a replacement there.
