Is a 99 Impreza 2.2L an interferance engine?
most likely toast. Did she try and start it after the car died (most wifes would that's why I ask). If she did then it's 99.999% toast, if not... well, you could get lucky but it will take time and money to find out how much more time and money you'll need to put into it.
slapping on a belt (can even be used) to see if the motor is good is a good idea to know for sure. although a leak down test can be performed as is to tell you if you bent any valves.
a valve job isn't that bad of a job, will give you another 100,000 miles out of the car if done right (complete timing kit, seals, etc), and might be worth it.
ebay sells complete timing kits for around $200 - includes belts, all new timing pulleys, and tensioner. at 10 years old often the belt failure is just a symptom of old pulleys/tensioners. the bearings loose grease over time and cause the timing belt to fail.
that's where these ebay kits are so handy, i've bought tons of them.
Expanding on GG's comments.
That's not a bad belt at all to do.
I always pull the radiator 'cause I like a little room.
If a belt doesn't solve it I'd pull the engine to check the pistons, clean and reseal it and drop it back in for another 100k.
I believe 96 was the last year of non-interferance engines, they went to the interferance engine to gain a little horse power and torque. You could probably get the same hp gain on the pre 97 engine by adding a cool air intake.
I have seen quite a few people get lucky on these Phase II motors. It is totally worth installing a belt on it and then test running it. If the compression is good on all 4 you are golden
Worst case pull the heads and put a couple valves in. Very unlikely htat the whole motor is *toast*
Thanks for all the info, I am guessing if it was the belt it was caused by another components failure as I put that belt in only about 40K miles ago.
It's on the hook and should be here in a couple of hours.
I'll let you know what I find.
Bill
I thought they already had a cool air intake? There's a donkywongle that goes from behind the right front headlight into the air filter. Isn't that it?
I am guessing if it was the belt it was caused by another components failure as I put that belt in only about 40K miles ago.l
yep, that was my guess without even knowing anything:
i made that statement because it's true and common.
someone on here may have a spare used belt to send you. i probably have some EJ22 belts used i'd give you for shipping to help you test if you'd like.
MAY HAVE GOT LUCKY!
Pulled one of the covers and belt is intact, tension seems right.
Got a code P0340, Camshaft Position Sensor Circuit Malfunction.
Don't have a manual, anyone know the diagnostic steps to check this?
Or should I just get a new Camshaft Position Sensor and gamble?
How much could it cost ???? :lol:
Bill
A lot of us have those around as spares.
They can be a pain to remove with corrosion.
CHeck the wireing/connection first.
If noone close has any PM me and I'll see if I have any left or take one of a good running engine.
Wiring and connector looks good, It's only $80.00,
I'll probably just get one and give er a try. :-\
Bill
yeah, but which one, left or right? there are 2, should be the same, but one each side. i guess you could replace one with new, if it runs great, if not swap the removed one to the other side and try. if not .......
you can get a lot of used parts for 80$ .....
Now I'm curious - the 99 2.2 has TWO cam sensors?
I'm gonna have ot go open the hood of the on that I have here and look.
BTW I have a 99 Legacy 2.2 parts engine here. If there are 2 sensors on it I can look to see it they appear good.
All the idlers, water pump spin freely, both cams turn over with some resistance (valve springs) and "pop" over once the cam hits the apex of the lobe (did that make sense)?
I am hoping this is a good sign, maybe no valve damage.
I would think if a valve was bent, the cams would not "feel" normal.
But they may if a valve is plain old broken?
Is it a fair assumption that with a shot belt, the ignition would not even try to fire, even out of sync from the rest of the system?
I'll get a belt tomorrrow and find out wahts really messed up.
Bill
They always have some resistance. A lot of stuff is moving in there and usually being pushed by pretty strong forces.
I hope that you have the crank set properly before turning the cams.
Depending on when you are doing this you can get one of the left coast places to possibly overnight you an Ebay kit for sat delivery cheaper than getting idlers at the parts store.
You gotta guess just the one or all of them. Usually the second wimpiest is the one on the old style tensioner. The lower one is probably the single bearing one and now they are all double row idlers.
