Fordman Posted June 5, 2009 Share Posted June 5, 2009 how do you do it. this thing has been blinking 12:00 since we got it. i cant figure it out. its a am/fm cassette. it is a factory radio. Link to comment Share on other sites More sharing options...
Rooster2 Posted June 5, 2009 Share Posted June 5, 2009 Subaru has used several different OEM radios. Which one do you have? Can you take a digital picture, and post it here. If I see a picture of the face plate, I prolly can tell you how to set the time. Link to comment Share on other sites More sharing options...
Fordman Posted June 5, 2009 Author Share Posted June 5, 2009 it is a panasonic. here is a pic of it. i had assumed it was a factory radio. maybe i was wrong. Link to comment Share on other sites More sharing options...
Rooster2 Posted June 5, 2009 Share Posted June 5, 2009 (edited) Yes, it looks factory, just that Panasonic keeps changing radio models. I have both a 98 and 99 Leggies. Both have factory Panasonic radios, that are different from each other, and neither look like yours, still there are similarities, so here are my thoughts.......... Judging from your picture, I would try to set the time by pressing in, and continue holding in, the button marked display. While continuing to keep the button pushed in, after about 5 second, press either one of the radio station "tune" buttons. I am thinking one tune button will advance the clock time setting, the other button will retard the clock time setting. If this doesn't work, while continue to push in the display button, try pushing other buttons in. I have one radio that uses the station preset buttons to set the clock, while the display button is depressed. Yes, it is frustrating, just like setting the correct time on a digital watch. If you keep pressing buttons, I bet you will be successful. Edited June 5, 2009 by Rooster2 additional write up info Link to comment Share on other sites More sharing options...
ShawnW Posted June 5, 2009 Share Posted June 5, 2009 Hes on to it. Its press and hold disp and then press the button below defeat to advance hours one at a time and the button below eq to advance minutes. Link to comment Share on other sites More sharing options...
Fordman Posted June 5, 2009 Author Share Posted June 5, 2009 thank you that worked this time. i thought i had tried that before. i had almost given up on setting it. Link to comment Share on other sites More sharing options...
