Bandit987 Posted June 6, 2009 Share Posted June 6, 2009 Alright so I pulled on the hood cable to open my hood up and it broke, it broke somewhere under the hood, does anyone have an idea of how to get it open without causing any damage to my car? Link to comment Share on other sites More sharing options...
GeneralDisorder Posted June 6, 2009 Share Posted June 6, 2009 Model/Year?? Pull the grill and/or the bumper to gain access to the mechanism. GD Link to comment Share on other sites More sharing options...
mudduck Posted June 6, 2009 Share Posted June 6, 2009 If this is an ea82 car you should be able to get to the hood release from under the car and hook it eith a piece of wire or somthing similar. Then when you get the hood open, use the hood release that came out in your hand and hook it to the release mechanism and fish it through the grill. If I had a camera, I would take a picture, but I don't. Link to comment Share on other sites More sharing options...
Bandit987 Posted June 7, 2009 Author Share Posted June 7, 2009 Sorry new to posting, its an 87 Rx/ Ea82-t, thx for the tips im trying it right now. Link to comment Share on other sites More sharing options...
mudduck Posted June 7, 2009 Share Posted June 7, 2009 You should be able to see some cable atatched to the mechinism you need to pull to pop the hood. Link to comment Share on other sites More sharing options...
Bandit987 Posted June 7, 2009 Author Share Posted June 7, 2009 Thx a bunch that was easier than I thought. New problem though, I guess when I put my alternator in I didn't connect it :-\. I plugged it in and now I have no power at all. We tried to push start it, and even jump start it, both didn't work. I have been searching the forums for post about the same problem but nothing specific about my problem. I am guessing its a main fuse but when I bought the car I don't have the owners manual, have also checked the forums for that and nothing. I also just put a new battery in so pretty sure its not that. Link to comment Share on other sites More sharing options...
Twitch de la Brat Posted June 7, 2009 Share Posted June 7, 2009 If you tapped the hot lead (the bigger wire with looped connector) to anything you will have shorted out and melted a fusible link. I believe you have a fusible link box on the passenger's side of the engine compartment, at least that's where my BRAT's is located. There should be a a few wire underneath the cover. If one has a silver stripe running along it, that's your culprit. I just took a 60a sub fuse and connected it via some wire and wire clips. Twitch Link to comment Share on other sites More sharing options...
Turbone Posted June 7, 2009 Share Posted June 7, 2009 Fusible links are next to the battery, on the drivers side. Link to comment Share on other sites More sharing options...
Bandit987 Posted June 7, 2009 Author Share Posted June 7, 2009 Turbone said: Fusible links are next to the battery, on the drivers side. Little black box that look like old style fuses? Link to comment Share on other sites More sharing options...
Turbone Posted June 7, 2009 Share Posted June 7, 2009 Bandit987 said: Little black box that look like old style fuses? Yes. The links are insulated wires with spade terminals on the ends. Each one has a different rating, thats why the different colors. Link to comment Share on other sites More sharing options...
Niku-Sama Posted June 7, 2009 Share Posted June 7, 2009 has any one modified the wiring for the fusable links and replaced them with blade stlye fuses on these cars? i ************in hate fusible links Link to comment Share on other sites More sharing options...
Twitch de la Brat Posted June 7, 2009 Share Posted June 7, 2009 All you need are a few chunks of 10 gauge wire, 4, 1/2 wide spade clips, and a compatible fuse. I'll take pics of mine an upload them tomorrow. Twitch Link to comment Share on other sites More sharing options...
ShawnW Posted June 7, 2009 Share Posted June 7, 2009 Or hit a junkyard and grab a few spares for next to nothing. Link to comment Share on other sites More sharing options...
Bandit987 Posted June 8, 2009 Author Share Posted June 8, 2009 Twitch de la Brat said: All you need are a few chunks of 10 gauge wire, 4, 1/2 wide spade clips, and a compatible fuse.I'll take pics of mine an upload them tomorrow. Twitch Alright thx a bunch, that would help a lot I'm stuck right now trying to figure out if my battery is bad now cause apparently I have been running off just my batter, or if my alt is bad or if its the fuses, I do plan on converting the fuses to newer style ones. pics would be great. Link to comment Share on other sites More sharing options...
Twitch de la Brat Posted June 8, 2009 Share Posted June 8, 2009 Tah Dah!!!! PIX! This setup should work for you. And that's electrical tape wrapped around the fuse and connecting wires. I cut a hole in the top of fusible link cover so the fuse stuck outside the box. Twitch PS: I'll post pictures of my box soon. Link to comment Share on other sites More sharing options...
Bandit987 Posted June 8, 2009 Author Share Posted June 8, 2009 Looks good to me, thx for the pics ill try it out. Link to comment Share on other sites More sharing options...
Bandit987 Posted June 13, 2009 Author Share Posted June 13, 2009 Thx for the help, running again. Link to comment Share on other sites More sharing options...
