plodder Posted June 8, 2009 Share Posted June 8, 2009 I need a 1996 man tran for legacy outback SW. Production date 09/95. I believe the cutoff date is 05/09 and goes through most of 97, but am not surethe type is: Ty752 VABC A. Thanks Dann 360-303-7433 Bellingham WA area, What is a reasonable price, said and done?? ALSO !!!!! Can a pre 05/95 be converted with the electronics needed????:: Link to comment Share on other sites More sharing options...
mthoodsub Posted June 10, 2009 Share Posted June 10, 2009 What??? Your post doesnt say much of anything. Is it an ej22 or ej25? I know that any 2.2 trans will bolt up to any 2.2 engine. Ive got a 91 trans in my 95. With a manual trans theres not much electronics to be "converted" Link to comment Share on other sites More sharing options...
Gloyale Posted June 14, 2009 Share Posted June 14, 2009 96 Manual Outback will be a 2.2 with a 4.11 final drive trans. Cable Clutch. You can use any 90-96 Legacy or Outback trans. You will need to install the Speedometer sender from your Outback trans into the earlier ones. It screws in right where the cable goes. Link to comment Share on other sites More sharing options...
plodder Posted June 19, 2009 Author Share Posted June 19, 2009 96 Manual Outback will be a 2.2 with a 4.11 final drive trans. Cable Clutch. You can use any 90-96 Legacy or Outback trans. You will need to install the Speedometer sender from your Outback trans into the earlier ones. It screws in right where the cable goes. :banana:Hey thanks, I knew there was a difference,and I thought there was more to it only screwing the sender in, but it makes sense, I knew it bolted up, and that the 96 had more information to digest in its brain, I guess the actual speed the car is going is what the engineers at Subaru thought would make the difference, who knows? Thanks Dann Link to comment Share on other sites More sharing options...
