05/95 MT L.O.B. Buy or convert pre 05/95
plodder
I need a 1996 man tran for legacy outback SW. Production date 09/95. I believe the cutoff date is 05/09 and goes through most of 97, but am not surethe type is: Ty752 VABC A. Thanks Dann 360-303-7433 Bellingham WA area, What is a reasonable price, said and done?? ALSO !!!!! Can a pre 05/95 be converted with the electronics needed????::
What???
Your post doesnt say much of anything.
Is it an ej22 or ej25?
I know that any 2.2 trans will bolt up to any 2.2 engine. Ive got a 91 trans in my 95.
With a manual trans theres not much electronics to be "converted"
96 Manual Outback will be a 2.2 with a 4.11 final drive trans. Cable Clutch.
You can use any 90-96 Legacy or Outback trans. You will need to install the Speedometer sender from your Outback trans into the earlier ones. It screws in right where the cable goes.
:banana:Hey thanks, I knew there was a difference,and I thought there was more to it only screwing the sender in, but it makes sense, I knew it bolted up, and that the 96 had more information to digest in its brain, I guess the actual speed the car is going is what the engineers at Subaru thought would make the difference, who knows? Thanks Dann
