Ever Victorious Posted June 16, 2009 Author Share Posted June 16, 2009 i would clean it before sticking it in, clean parts is happy parts What, it's not like it's going in this weekend.. Link to comment Share on other sites More sharing options...
coxy Posted June 17, 2009 Share Posted June 17, 2009 Remember as well if you plan to reuse the clutch always replace the throwout bearing regardless,it is easy to inspect a pressure plate and clutch disk for its potential lifespan however its not worth the grief of having to pull the trans again for a throwout race. Also a good time to make sure the rear main seal is good to go as well. It doesnt matter what you do to any Subie as long as you keep it rockin on that is what really matters in the end. Link to comment Share on other sites More sharing options...
Niku-Sama Posted June 17, 2009 Share Posted June 17, 2009 hmm i dont remember there being a clutch on the trans we pulled, but yea to the throw out bearing, since your already there any way and closer with out a clutch is there going to be a difference in clutch size between the trans he has and the one thats going in? Link to comment Share on other sites More sharing options...
Ever Victorious Posted June 17, 2009 Author Share Posted June 17, 2009 I think GD said the clutch is the same between the 4WD and FWD ea81 trans. The clutch in the BRAT is already brand new, so I was just planning on reusing it. Link to comment Share on other sites More sharing options...
