baccaruda Posted June 11, 2009 Share Posted June 11, 2009 Hello, I have a 2001 Legacy Outback Wagon which has a bad 5-speed transmission. I have the following list of possibly compatible transmissions and their part numbers and originating cars.. I'm concerned about whether the wiring harnesses will interchange. If anyone can help me narrow this list down it would help me immensely I also have pictures of the wiring harness on the bad transmission which is after the list. Thanks! 5MT Transmission (Push Clutch) 93 Impreza _____________TY752VX3AA 94 Impreza _____________TY752VX3CA 98 Impreza 2.5RS ________TY752V2DAA 99-01 Impreza 2.5RS _____TY754VCAAB 02-03 Impreza 2.5RS _____TY754VFBBA 04 Impreza RS ___________TY754VC4CA 97-98 Forester __________TY753VJ1AA 99 Forester _____________TY755VC1AA 00-01 Forester __________TY755VC1BA 02 Forester _____________TY755VC2AA 03 Forester ____________ TY755VC3AA 04 Forester (NA) ________ TY755VC4AA 94 Legacy OB ___________TY752VAAAA 95-96 Legacy OB ________TY752VABBA 97 Legacy GT __________ TY752VACBA 97 Legacy OB ___________TY752VACCA 98 Legacy GT ___________TY752V2DAA 98 Legacy OB __________ TY752V2DCA 99 Legacy GT ___________TY754VCAAB 99 Legacy OB ___________TY754VCACB 00 Legacy OB ___________TY754VCACA 00 Legacy GT __________ TY754VCADA 01-02 Legacy GT ________TY754VCBDA 03-04 Legacy L _________ TY754VCDAA 03-04 Legacy GT ________TY754VCDDA 03-04 Legacy OB / Baja ___TY754VCDCA 05 Legacy / Baja _________TY757VCACA 05 Legacy OB ___________ TY757VWAAB Link to comment Share on other sites More sharing options...
Legacy777 Posted June 11, 2009 Share Posted June 11, 2009 I think after 95 the Legacy had the electronic speed sensor vs. the cable. However you can change the speed sensors over, so that's not a problem. The electrical really shouldn't be a problem. Those plugs could be changed if need be. The main thing you need to make sure is that the final drive ratio matches. Link to comment Share on other sites More sharing options...
baccaruda Posted June 11, 2009 Author Share Posted June 11, 2009 Thanks Josh. Every transmission in that list I typed is a 4.11 ratio.. I could always match the diff if I put in a different ratio but I'd prefer to keep it original. Changing the electrical components wouldn't be hard either.... cheers! Link to comment Share on other sites More sharing options...
subaru360 Posted June 11, 2009 Share Posted June 11, 2009 The only thing you really need to match is axle ratio. Any sensors or switches that are different can be swapped over. Link to comment Share on other sites More sharing options...
baccaruda Posted June 11, 2009 Author Share Posted June 11, 2009 Thanks, I've got my name on a 2.5RS transmission at Spaldings. 98 Impreza 2.5RS ________TY752V2DAA from my list. Link to comment Share on other sites More sharing options...
