michael appel Posted June 14, 2009 Share Posted June 14, 2009 when I put my 4wd low in gear on dry pavement it shakes furiously when it drives what do you think is the problem I need to fix it. The wagon has a 4inch lift maybe the driveline has to much stress? Quote Link to comment Share on other sites More sharing options...
michael appel Posted June 14, 2009 Author Share Posted June 14, 2009 Sorry I meant to put my other lifted wagon has no problem in low on pavement Quote Link to comment Share on other sites More sharing options...
bratman18 Posted June 14, 2009 Share Posted June 14, 2009 Are the tires all the same size? Or are the wearing the same? Quote Link to comment Share on other sites More sharing options...
mudduck Posted June 14, 2009 Share Posted June 14, 2009 Sounds like things are binding up. Don't put it in 4wd on pavement. Quote Link to comment Share on other sites More sharing options...
Gloyale Posted June 14, 2009 Share Posted June 14, 2009 Carier bearing or perhaps a rear axle. Quote Link to comment Share on other sites More sharing options...
NorthWet Posted June 14, 2009 Share Posted June 14, 2009 when I put my 4wd low in gear on dry pavement it shakes furiously when it drives what do you think is the problem I need to fix it. The wagon has a 4inch lift maybe the driveline has to much stress? Maybe its because you are not supposed to use 4wd on dry pavement??? Quote Link to comment Share on other sites More sharing options...
RAugur33 Posted June 14, 2009 Share Posted June 14, 2009 Hey Michael, Which wagon is shaking, the one with the welded rear or the new one? Quote Link to comment Share on other sites More sharing options...
mudduck Posted June 15, 2009 Share Posted June 15, 2009 You got a tire or two worn more than the others? If I put mine in 4wd on pavement it will bind and hop a little. I also have missmatched tires. Same size, different treads. No problem in the dirt. What happens when you use 4wd in the dirt? Quote Link to comment Share on other sites More sharing options...
