My speedo has been acting up. From 0-20mph in traffic at low speeds, my speedo has been bouncing up and down. What would cause this?? After about 10mph (actual speed) it levels out and is fine. I am baffled.
thats a hard one, as you can either have a cable or en electronic spedo. 1995 is when they switched.
Look under the hood, at the firewall around the master cylinder. You will see one cable, for the gas pedal. Do you see a second cable that loops down to the transmission?
Do you have any CEL lights?
nipper
a friends 97 Impreza Auto EJ22 AWD is doing the same, i'd be interested to see what this is.
hopefully it's something simple because the driven gears in the trans aren't going to be replaced by most folks (intensive, costly, or both).
Your speedo is driven by a cable comming from the transmission. You can check up my log about regreasing the cable inside. maybe the notch is worn.
true on older models, newer ones have a pair of wires from the front speed sensor on the trans/front diff, passenger side kind of low, to the speedo.
depending which is cheaper or easier to come by, replace the sensor or speedo. i always thought it was the sensor.
