Petersubaru Posted June 19, 2009 Share Posted June 19, 2009 has anybody conclusive information as to why the front bottom caliper pin has a rubber end attached to it...even after re-greasing them, all is moving freely and smoothly, but shortly after, these particular pins get seized up again in a few days of brakeing...the other pins are OK...why is it the aftermarket sells the subaru slider pins without the "rubber" ends Link to comment Share on other sites More sharing options...
CNY_Dave Posted June 19, 2009 Share Posted June 19, 2009 I thought in http://ultimatesubaru.org/forum/showthread.php?t=99382&highlight=caliper we pretty much figured out that it kept the caliper from wandering? Dave Link to comment Share on other sites More sharing options...
OB99W Posted June 19, 2009 Share Posted June 19, 2009 has anybody conclusive information as to why the front bottom caliper pin has a rubber end attached to it...even after re-greasing them, all is moving freely and smoothly, but shortly after, these particular pins get seized up again in a few days of brakeing... Could you define ''seized up'', and how you're making that determination? Also, what specific lubricant are you using? Link to comment Share on other sites More sharing options...
Petersubaru Posted June 20, 2009 Author Share Posted June 20, 2009 Could you define ''seized up'', and how you're making that determination? Also, what specific lubricant are you using?...Silicone Brake lub from Napa..defining "seized up" would mean that the caliper pin can not freely move " in and out" without the use of plyers Link to comment Share on other sites More sharing options...
hohieu Posted June 20, 2009 Share Posted June 20, 2009 That's normal for the "lock pin" to do that. It requires constant steady pressure to remove. The rubber used on these pins is a bit soft as compared to others I've seen, which makes them more difficult to remove. These calipers are Akebono designs, and they're excellent. I see them increasingly used on non-Japanese brands to remedy known issues with their previous designs. Link to comment Share on other sites More sharing options...
