Loyale93v Posted June 20, 2009 Share Posted June 20, 2009 93 spfi 1.8L Loyale. trying to retrieve current and historical DTC's. Under my hood drivers side up near the fire wall, there are a few connecters. A pair of green ones, A small pair white-ish ones, and a black one, and a yellow one. What is the "right" way to exicute the reading of past and present DTC's? What I did was removed the panel from underneath the steering column to expose the ECU. I then connected the two green connecters, and the ECU flash the little red light seven times. It repeated the seven flashes infinately. I then connected the small white-ish connecters, the MIL on dash blinked continuosly. The Ignition key was in the "RUN" position during both tests.(Key On Engine Off) Am I doing this correctly?And is there more that I can do? Link to comment Share on other sites More sharing options...
Cougar Posted June 20, 2009 Share Posted June 20, 2009 Here is a link to a site that may help you. http://www.troublecodes.net/Subaru/ Link to comment Share on other sites More sharing options...
GeneralDisorder Posted June 20, 2009 Share Posted June 20, 2009 Read the PDF I linked in your other post. It will answer your questions. GD Link to comment Share on other sites More sharing options...
