Ignition coil spec's....?
Does any one have the FSM specification for the ignition coil on my 93 SPFI
f4-1781cc 1.8L Loyale? I am looking for the out put volts and anything else I should know about it. NOTE: please do not post "PDF" format as my PC is not able to read it for the time being. Thank You.
Loyale93v
Primary coil resistance: .84-1.02 ohms
Secondary coil resistance: 8000-12000 ohms
Insulation resistance between case and primary terminal: more than 10m ohms
This is straight out of the 1989 FSM
thank you , this will be most helpful.
