SubaruWagon87 Posted June 24, 2009 Share Posted June 24, 2009 I accidentally stumbled across this thread on nasioc, and after talking to the guy, I'm pickin this baby up tomorrow: (for $250!!!) Link to comment Share on other sites More sharing options...
bheinen74 Posted June 24, 2009 Share Posted June 24, 2009 cool. as always, you guys get all the deals of non rust bucket Subaru's Link to comment Share on other sites More sharing options...
The Beast I Drive Posted June 24, 2009 Share Posted June 24, 2009 I think thats the one I was thinkin of buyin a while back, but I just didnt have the ambition to go get it... Nice score -Bill Link to comment Share on other sites More sharing options...
The Scooby Posted June 24, 2009 Share Posted June 24, 2009 lol ya i almost bought that a few months ago because its a twin to my lifted wagon for spare parts. just run it for a while and make sure it doesn't overheat or be down on power because needless to say, good luck finding another EA82 that is worth a darn. Link to comment Share on other sites More sharing options...
zyewdall Posted June 24, 2009 Share Posted June 24, 2009 Nice. I used to own the almost twin of that car -- light blue '85 wagon -- mine had the digidash and the sunroof though. And I paid $500 for it Z Link to comment Share on other sites More sharing options...
SubaruWagon87 Posted June 26, 2009 Author Share Posted June 26, 2009 Drove it home last night:banana: Almost overheated driving thru town (no fan) but cruisin at 50 it did fine. Now all I have to do is get it licensed, clean it up, reseal the motor, and I'll be in business! (oh, and get it to run right) Link to comment Share on other sites More sharing options...
SubaruWagon87 Posted June 27, 2009 Author Share Posted June 27, 2009 Ok, so I've decided not to do a reseal, it looks like its only leaking oil thru the valve cover gaskets, which a set came with the car, so I'll be replacing them later today. I made it run a little better by swapping in a carb from my other soob, but it dies if I don't keep giving it gas. It seems like its a vacuum issue. Which brings me to my question, what vacuum lines does the car need to run? Link to comment Share on other sites More sharing options...
The Beast I Drive Posted June 28, 2009 Share Posted June 28, 2009 swap a Weber on it, re-time it and you'll be good to go. I found a Weber on an old soob at a junkyard the other day, got it for 15 bucks -Bill Link to comment Share on other sites More sharing options...
SubaruWagon87 Posted June 29, 2009 Author Share Posted June 29, 2009 I would like to weber it, but for the time being, I'm gonna leave the craptachi on there. Link to comment Share on other sites More sharing options...
SubaruWagon87 Posted July 14, 2009 Author Share Posted July 14, 2009 Rather than start a new thread, I'll bump this one back up. I was going to replace the valve cover gaskets, but when I crawled underneath to check things out, it appears that the driver's side cam seal is what's leaking (I can watch oil drip when the car's running). How hard is it to replace the cam seals? Link to comment Share on other sites More sharing options...
subaruguru Posted July 14, 2009 Share Posted July 14, 2009 (edited) not hard at all you need to remove the T belt covers and belts then the cam gear use a seal puller to remove the old and then replace with new ones then put it all back together helped a friend with it easy stuff. i have a set of NEW subaru cam seals 20 and there urs. now if its the cam case itself you need to remove the valve cover then the whole cam case carful not to drop ur rockers they will fall off but can be put back on. then seal with High tmp RTV. worked great on mine. let me know on the seals i have them here in the baggies Rob. just looked there is a crank seal in there too. Edited July 14, 2009 by subaruguru Link to comment Share on other sites More sharing options...
SubaruWagon87 Posted July 14, 2009 Author Share Posted July 14, 2009 I might take you up on that. I get paid on the 25th, I'll let you know then. Link to comment Share on other sites More sharing options...
subaruguru Posted July 14, 2009 Share Posted July 14, 2009 sounds good i also take trades. Link to comment Share on other sites More sharing options...
