740gle Posted June 26, 2009 Share Posted June 26, 2009 After strong rains, or snow melts, i notice the watter dripping from the map lights, and way in the back in the cargo area. I did not see any obvious leak sources in the roof, the rack attachment points seem solid and tight, so I guess it comes around the sunroofs. Is it because of clogged the sunroof drain(s)? Where are they? How can I clean them? Thanks for the advice, -Michael Link to comment Share on other sites More sharing options...
ronemus Posted June 27, 2009 Share Posted June 27, 2009 There are drain lines at all four corners of the drip tray under the sunroof. They do tend to get clogged after a while. You can either pull the headliner and blow them out from above, or pull the fender liners and clear them from below. They have a flap covering them at the lower end that sometimes sticks closed, so sometimes you have to cear them from the bottom. Link to comment Share on other sites More sharing options...
740gle Posted June 27, 2009 Author Share Posted June 27, 2009 How do I pull the headliner? Do the drains run down to the rear or front wheels? Both left and right? Sorry, for simple questions - had no experinece with the interior, -Michael Link to comment Share on other sites More sharing options...
