26i4x4guru Posted June 27, 2009 Share Posted June 27, 2009 HEy i got an 82' EA81 that im lifting for a wheeler. Since its going to be a wheeler and it has the d/r tranny can i weld up the spider gears in the rear diff and not have any issues during road driving. How complicated is it to weld up the gears. Link to comment Share on other sites More sharing options...
monstaru Posted June 27, 2009 Share Posted June 27, 2009 search is your friend. Link to comment Share on other sites More sharing options...
SoobieDoo Posted June 28, 2009 Share Posted June 28, 2009 If it's a daily driver, then the welded diff may not be the best choice. It will skip during sharp turns, such as parking lots and cause premature tire wear. You could always weld up a spare and just swap them out before wheelin. Link to comment Share on other sites More sharing options...
mcbrat Posted June 28, 2009 Share Posted June 28, 2009 I ran a welded diff, and just pulled one of the rear axles for daily driving..... Link to comment Share on other sites More sharing options...
SoobieDoo Posted June 28, 2009 Share Posted June 28, 2009 I ran a welded diff, and just pulled one of the rear axles for daily driving..... Excellent idea! I'd much rather store just an axle and not have to buy an extra diff. Link to comment Share on other sites More sharing options...
86HatchShelby Posted June 28, 2009 Share Posted June 28, 2009 Ran a welded diff with both axles in the back for over a year, no problems... rear tire blew up mysteriously though Just pull an axle in the back -Jaren Link to comment Share on other sites More sharing options...
Sweet82 Posted June 29, 2009 Share Posted June 29, 2009 You can pull the axle in 2 minutes or less! Once it's been out the first time... I used a nail to keep my axle in/out for a year. Link to comment Share on other sites More sharing options...
Phizinza Posted June 30, 2009 Share Posted June 30, 2009 I've been using a welded diff in my sedan with both axles in for about 6 months now. Although the car doesn't get much driving. I found pumping the 27" MT's up to 40psi in the rear really helped with screeches, heavy steering, and economy. I'd take out a shaft but I've got a lot of dirt roads around my place and 3WD sucks... Link to comment Share on other sites More sharing options...
