kanurys Posted October 3, 2012 Share Posted October 3, 2012 (edited) Would you show us where you put the ECU and relays? Nice work on the swap. I did kind of the same thing for the lower radiator hose. I used a piece of PVC as a sleeve. The upper one was a Gates 20801. It has the right sized ends and I cut about 2" out of the middle and spliced it for my 4" lift, so you'll probably be good without modifying. You might want to splice it in the middle anyways to be able to rotate it as needed. Do you have a number on the lower hoses you picked up? I'd like to ditch my flex hose for the U. Edited October 3, 2012 by kanurys Link to comment Share on other sites More sharing options...
