hello all , this model was never officialy imported to new zealand so no subaru dealers have any info on this car , it has adjustable valve clearences , i need to know the clearences to adjust my inlet and exhuast valves ...any info that some one has or point me to a website that has this would be most helpful ... many thanks for any replies
cheers blair
I'm not sure if you're going to find much info on here, as the US didn't get the 1.5 liter model either. You may want to try a Subaru board in Europe/UK.
Other suggestion would be to find specs from newer subarus without hydraulic lifters and use that. You may have to do some trial and error.
Check around under the hood/bonnet for a sticker. Often times the manufacture will put one there with tune up specs. Another option, at least here in the States, is to go to the local library and request the factory service manual for this model. The librarian will contact other libraries until the manual is found. May take a week or more.
