suberdave Posted July 3, 2009 Share Posted July 3, 2009 well it will work. hoever i had to drop the rear diff 1/4in. its a close call between the shaft and the tunnel. i dont have any pics of it in the car, but here is a pic of the old and new shaft. reason for doing a one peice shaft, is the 4EAT shaft i got from a wreking yard had a bad joint. it also had a qustianable carrier bearing. Link to comment Share on other sites More sharing options...
Jerry DeMoss Posted July 3, 2009 Share Posted July 3, 2009 Ya that will work no problem. Alot of people run a one piece drive shaft (me included) on their ea81 cars with a 5spd swap in them so you shouldn't have an ounce of trouble. Link to comment Share on other sites More sharing options...
Numbchux Posted July 3, 2009 Share Posted July 3, 2009 my home-made carrier mount in my loyale kept eating carrier bearings....so I had an EA81 shaft lengthened.....it's worked pretty well for ~10-15k miles. only problem, is with the shot rear diff bushing, and ebrake handle bolts sticking down in the tunnel, it rubs when I'm hard on the throttle. before I sell it, I need to get in there and flip those bolts around so they don't stick down so much (and replace the diff bushing...). Link to comment Share on other sites More sharing options...
Flowmastered87GL Posted July 3, 2009 Share Posted July 3, 2009 Ya that will work no problem. Alot of people run a one piece drive shaft (me included) on their ea81 cars with a 5spd swap in them so you shouldn't have an ounce of trouble. But he has an EA82, the floor pans are shaped different. Link to comment Share on other sites More sharing options...
mykingcrab Posted July 5, 2009 Share Posted July 5, 2009 (edited) So this work in a stock ea82t d/r 5 speed???????? 1985 4 door RX to be exact???????? Edited July 5, 2009 by mykingcrab Link to comment Share on other sites More sharing options...
tallwelder81 Posted March 25, 2010 Share Posted March 25, 2010 excuse me if this is a dumb question with an obvious answer, but WHAT is the benefit of a single piece driveshaft? is that just for less rotational losses? less reciprocating weight? unsprung weight? please explain it to me, i will accept being laughed at cuz as i write this, i already get the feeling the answer is day 1 logic. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted March 26, 2010 Share Posted March 26, 2010 excuse me if this is a dumb question with an obvious answer, but WHAT is the benefit of a single piece driveshaft? is that just for less rotational losses?less reciprocating weight? unsprung weight? please explain it to me, i will accept being laughed at cuz as i write this, i already get the feeling the answer is day 1 logic. Primarily because with a single peice shaft you have fewer moving parts - less to fail. Stock EA82 two-peice units are not serviceable without modification and in some parts of the country they are very scarce in the used market as well. Add to this the cost of a replacement stock assembly at somewhere around $600 to $800 and you can see why people would rather pay ~$150 for a new shaft that has serviceable u-joints, etc. The price for converting a stock shaft to serviceable joints runs about the same. It's an economic decision more than anything. Here in the NW where used shafts are plentiful and rarely fail due to our lack of rust - we just run the two-peice unless there's a need to do a one-peice because of size limitations (EA81 hatch with a 5 speed for example). GD Link to comment Share on other sites More sharing options...
Numbchux Posted March 27, 2010 Share Posted March 27, 2010 I only did it because my wagon used to be FWD, so there was no mounts for the carrier bearing. I tried to fabricate something, but the bearing failed pretty quickly. had a one-piece shaft made, and it lasted a long time. Link to comment Share on other sites More sharing options...
