dakos Posted July 6, 2009 Share Posted July 6, 2009 hi, i'm trying to find out what's the order of the cylinders, which one is cylinder nr 1 ,2 3 and 4. i'm getting a missfire on the nr 3 but i don't know which one is it? thanks a lot! Quote Link to comment Share on other sites More sharing options...
rvac99 Posted July 7, 2009 Share Posted July 7, 2009 When looking at the engine, #1 is the front on on the left or the passenger's side. #3 is right behind #1. 2 and 4 are on the driver's side with #2 being the most forward of the two. There should be numbers on the ignition coil where the spark plug wires end. Quote Link to comment Share on other sites More sharing options...
Jerry DeMoss Posted July 7, 2009 Share Posted July 7, 2009 I second that. Just as he said. Quote Link to comment Share on other sites More sharing options...
dakos Posted July 7, 2009 Author Share Posted July 7, 2009 thank you very much! Quote Link to comment Share on other sites More sharing options...
Rooster2 Posted July 7, 2009 Share Posted July 7, 2009 misfire generally caused by a bad spark plug or plug wire, in case you don't already know this. Quote Link to comment Share on other sites More sharing options...
dakos Posted July 7, 2009 Author Share Posted July 7, 2009 ..i have replaced the sparkplugs couple of months ago...and the car just started to have this problem last week or soo...strange is that it's starting nice and does idle smooth , it happens only when accelerating some time ..and i can feel the car hesitating... i'll double check the sparkplug and i want to change the wires between 3 and 1 and see if that will change the missfire cylinder nr... Quote Link to comment Share on other sites More sharing options...
dakos Posted July 10, 2009 Author Share Posted July 10, 2009 ok...i have interchange the sparkplugs wires between cyl 1 and 3 and it looks like the problem is gone... no more missfire and i can step on the gas again without any engine hesitation ... ps the ingnition coil has the cyl nr on it and also the wires should have checked before asking thanks a lot anyways !! Quote Link to comment Share on other sites More sharing options...
