EA82 manual brakes?
Did the EA82's come with manual brakes? When i switch to the motorcycle engine im going to lose power brakes so ill need to ditch the booster. It would be great if i could just bolt up a manual brake cylinder, possibly from an EA81?
Thanks.
in order to get your power brakes you can use a 12 volt vacuum pump
like these
http://biodiesel.infopop.cc/eve/forums/a/tpc/f/919605551/m/7331015712
http://www.instructables.com/id/convert-a-tire-inflator-type-air-compressor-into-a/
http://motors.shop.ebay.com/items/?_nkw=12+volt+vacuum+pump&_armrs=1&_from=&_ipg=&_newu=1&_sop=1
http://www.autoanything.com/brakes/69A3151A0A0.aspx
Ive seen the fourth one or like used on heavyly camed motors with little to no vacuum
Edited by bobaru
If you want to go to manual brakes, like absolutely have to, for clearance issues or what not, the old old '71-73 EA series cars had manual brakes, i.e. Gen 1 stage 1s with EA62 or EA63 engines from 71-73 at least. Other years may have had them too. I dont know if the brake pots will work in a later EA car like your Sedamn, but you could look into that...
-Bill
