What the ???? is this thing
hey
do any of yall know what this thing is what it does, and what it affect....and what the hell it connects to b/c the other end looks like the wires been stripped and if so what wire is supposed to connect to it...the other end of the thing connects to the ignition coil +terminal...and it looks to me something should be goin to the other side of this thing.....thanx
john sellers
85 brizat
1.8 2bb Hicrappy
heres the link to the thing
http://www.snapfish.com/thumbnailshare/AlbumID=10674685/t_=8611836
OK, that is a condensor or resistor. It is used to primarily reduce static and radio noise I believe. You can get one off just about any Subaru in the junkyard. I reccommend taking the engine attachment bracket off instead of trying to unscrew it. Then remve the connection at the coil. Not an absolutely neccessary part but it is reccommended to use it. You may even be able to get it new from a dealer but it is probably pricey knowing the dealer pricing.
Yeah - thats a condensor of some sort if I'm not mistaken. The one on my Brat was broken just like that - in fact - many of the ones I've seen are broken. The wire pulls out of the unit - it looks stripped when it does that. I didn't notice any adverse effects from not having one, but I replaced it when I located a good one at the JY. No difference with a good one. It just doesn't seem to have much effect either way.
