SubiPilot Posted July 10, 2009 Share Posted July 10, 2009 howdy folks, Had a frustrating problem with Subi 2 this past week and after replacing likely culprits I still have a problem of losing 2 cylinders after the engine warms up. While driving the car I suddenly lost 2 cylinders and the Check Engine Light was blinking. Replaced the coil, wires, plugs, cleared a clogged cat, and replaced a fuel injector. It runs great until it warms up and then I lose the 1 & 2 cyliinders. Subi 2 has 290k miles on her and ran like a bear up until this happened... Any ideas or thoughts? Mal Link to comment Share on other sites More sharing options...
Fairtax4me Posted July 10, 2009 Share Posted July 10, 2009 Did you get anything besides misfire codes from the CEL? (assuming that you had it scanned) Have you tried pulling the plug wires off the 1&2 to see if they're still getting spark when this happens? Link to comment Share on other sites More sharing options...
SubiPilot Posted July 10, 2009 Author Share Posted July 10, 2009 The only codes were for misfire. When this happens there is no spark on 1 or 2. Mal Link to comment Share on other sites More sharing options...
bheinen74 Posted July 10, 2009 Share Posted July 10, 2009 timing belt not timed on the correct marks. Link to comment Share on other sites More sharing options...
SubiPilot Posted July 10, 2009 Author Share Posted July 10, 2009 it only misfires after warming up... not when first started we also have compression... mechanic is checking the igniter tomorrow Mal Link to comment Share on other sites More sharing options...
Fairtax4me Posted July 10, 2009 Share Posted July 10, 2009 Probably the ignition module. Link to comment Share on other sites More sharing options...
Cougar Posted July 11, 2009 Share Posted July 11, 2009 I suggest you check the crank sensor signals and see if they are ok when the trouble happens. If that is ok then I would look into trying to find a spare ECU and see if replacing that helps. I assume the wiring to the ignition module has been checked for a problem already. Link to comment Share on other sites More sharing options...
SubiPilot Posted July 23, 2009 Author Share Posted July 23, 2009 Problem solved! Turns out it was a flat plastic coupling/relay looking thing my mechanic called an 'igniter' Apparently all the good stuff they put on the roads in the winter here in the northeast corroded it and it was causing the misfire. Subi 2 is running strong again. 291k miles now. Mal Link to comment Share on other sites More sharing options...
