etc Posted July 12, 2009 Share Posted July 12, 2009 1998 Legacy L, 2.2L auto. I was replacing radiator and other stuff. I put it all back but now cannot figure out how to put back the dual fans. Does anyone have a pic of how it should be done? Link to comment Share on other sites More sharing options...
lmdew Posted July 12, 2009 Share Posted July 12, 2009 Passenger side will slip in first. Start the bolts but do not tighten them. Install the Drivers side fan, start all the bolts and tighten them up. Plug in the fans and install the overflow bottle. Link to comment Share on other sites More sharing options...
EVOthis Posted July 12, 2009 Share Posted July 12, 2009 +1 ^..pretty simple...the only time its a little more difficult to remove is when both fans are one unit on some of the newer foresters and such as to where the upper rad. hose/neck gets in the way.... Link to comment Share on other sites More sharing options...
etc Posted July 12, 2009 Author Share Posted July 12, 2009 The problem is, being the mechanical genius that I am, I cannot figure out which one is the passenger side and more importantly which side is up and down or left/right. Plus I cannot find where they mount to. A pic would be *really* helpful. Link to comment Share on other sites More sharing options...
Gloyale Posted July 12, 2009 Share Posted July 12, 2009 electrical connectors go on the bottom, to the outside. So just put them in with the wiring at the bottom outside corners. They will only fit one way. It is actually easier to remove the whole radiator with fans attached for future reference. Link to comment Share on other sites More sharing options...
etc Posted July 12, 2009 Author Share Posted July 12, 2009 So they bolt to the radiator? I need to look more carefully. Link to comment Share on other sites More sharing options...
OB99W Posted July 12, 2009 Share Posted July 12, 2009 So they bolt to the radiator? [...] Yes, although if you replaced the radiator, you'll have to transfer the speed-nuts from the old one for some of the positions. Link to comment Share on other sites More sharing options...
etc Posted July 13, 2009 Author Share Posted July 13, 2009 I got it -- thanks. Note to self: Take pictures of everything upon taking it apart. Link to comment Share on other sites More sharing options...
nipper Posted July 13, 2009 Share Posted July 13, 2009 I got it -- thanks. Note to self: Take pictures of everything upon taking it apart. we love cell phone cameras for this reason nipper Link to comment Share on other sites More sharing options...
