turbo to mpfi ecu question
Hi Gang
I have a turbo 89 with a blown motor, i was going to put a mpfi 89 engine in it to tie over while i rebuild the turbo engine. Will i need to swap the turbo ecu or will it run the mpfi ok.
Cheers Pete
The Turbo ECU will runt he NA motor fine.
I have a hybrid EA82 in my car right now.
EA82T block
SPFI pistons (9.5:1)
NA Spider intake
Running great using the Original Turbo ECU and MAF
There is sometimes a slight lag in throttle response at low RPMs, but overall it runs great.
