SDSOOBI Posted July 13, 2009 Share Posted July 13, 2009 Hey guys, given the error code that I'm receiving my crank angle sensor in the dizzy is bad. I'm wondering if there is a difference between the 86 and 88 models? For an 86 I see this model as a reman by A1 cardone - A131853 and for an 88 this model as a reman by A1 cardone - A131854 The only difference I can see is that the 88 model is for turbo, FI and carb whereas the 86 is for gas, FI. The auto parts store can't tell me the difference other than the model number. Reason I'm asking is I can get a dizzy for an 88-91 off ebay for $95 versus paying $200+ from the auto parts store for an 86. Link to comment Share on other sites More sharing options...
naru Posted July 14, 2009 Share Posted July 14, 2009 Big difference. Pretty sure 854 is an optical dizzy and 853 is none optical.Not compatible.Neither one comes w/the required electrical module,either. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted July 14, 2009 Share Posted July 14, 2009 (edited) '83 - '86 Turbo's use a different, and older style distributor. The ignition advance is still partially mechanically controlled with a vacuum pot and mechanical advance. The '87+ distributor's are 100% electronic with no advance mechanisms at all. So no, they are not compatible. Unless you are refering to the (rare) '86 SPFI used on high-end 2WD's.... in that case it's the same but you will have to change the plug. GD Edited July 14, 2009 by GeneralDisorder Link to comment Share on other sites More sharing options...
SDSOOBI Posted July 14, 2009 Author Share Posted July 14, 2009 Just to clarify this is the distributor I currently have... No vacuum advance and no module. http://cpwstore.carpartswholesale.com/catalog/details/Subaru/GL/A1_Cardone/Distributor/1986/Base/4_Cyl_1-dot-8L/A131853.html Link to comment Share on other sites More sharing options...
tturnpaw Posted July 14, 2009 Share Posted July 14, 2009 I own an 09/85 2wd sedan FI. Much different? I believe its the first one they really sold. Auto, power everything, a/c. It did have a check engine code but it also had a very old o2 sensor. I could part with the dist. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted July 14, 2009 Share Posted July 14, 2009 I own an 09/85 2wd sedan FI. Much different? SPFI or MPFI? '85 2WD's used the (rare) non-turbo MPFI system. With that build date though it could be an early '86 with the SPFI. GD Link to comment Share on other sites More sharing options...
GeneralDisorder Posted July 14, 2009 Share Posted July 14, 2009 Just to clarify this is the distributor I currently have... No vacuum advance and no module.http://cpwstore.carpartswholesale.com/catalog/details/Subaru/GL/A1_Cardone/Distributor/1986/Base/4_Cyl_1-dot-8L/A131853.html Then I take it you have an SPFI system with no turbo? A 2WD then I'm guessing? In which case ANY 87+ fuel injection distributor will work for you. You *may* have to change the plug but the actual distributor is the same. GD Link to comment Share on other sites More sharing options...
SDSOOBI Posted July 14, 2009 Author Share Posted July 14, 2009 yes... 1.8L, SPFI, non-turbo, 2WD Link to comment Share on other sites More sharing options...
Gloyale Posted July 14, 2009 Share Posted July 14, 2009 Not to make things more confusing, but why excactly are you replacing the distributor? I mean, you are getting a code we know but what is the actual running problem you are having? the reason I ask, is because the Crank Angle codes (12 IIRC) will trigger in D-check when you turn Key On/Eng Off. But if the car will start, then your CAS and whole disty are likely fine. Link to comment Share on other sites More sharing options...
SDSOOBI Posted July 14, 2009 Author Share Posted July 14, 2009 The error code I'm receiving is the 1 long 1 short => crank angle sensor which is in the distributor correct? And the repair manual I've been using states when this component is faulty you have to replace the entire dizzy. Also please see my other post regarding troubleshooting this issue. http://www.ultimatesubaru.org/forum/showthread.php?t=100886 I have an ignition amplifier on the way thanks to 4x4_Welder. But I'm guessing this part will not solve my problem...Thus I'm beginning the search/research for a replacement dizzy. Link to comment Share on other sites More sharing options...
