eventoday Posted July 14, 2009 Share Posted July 14, 2009 hello, I have an 01 outback with 214k on it. I have been noticing a metal sounding clank when i hit bigger bumps. Sounds like it is coming from under the the middle of the car. i have looked under the car but haven't noticed any missing bolts or anything that looks unsecure. I know this is kinda vague but any ideas? could it be anything to do with the transmission:slobber:? thanks jake Link to comment Share on other sites More sharing options...
idosubaru Posted July 14, 2009 Share Posted July 14, 2009 Can you give any more info? 01 outback - H6 or EJ25? Probably something benign if you don't have any other issues. My first thoughts are heat shields (very common noise makers) or front struts, at that mileage they could easily need replaced. Of course typical ball joints and tie rods should be checked as well, looking in particular for broken boots/leaking grease. Link to comment Share on other sites More sharing options...
davebugs Posted July 14, 2009 Share Posted July 14, 2009 Hey - you need to start more threads! A lot of times when this happens and the struts look good it's the mounts. Infact I believe GG just had an issue with mounts. Link to comment Share on other sites More sharing options...
eventoday Posted July 14, 2009 Author Share Posted July 14, 2009 sorry I forgot that made a 3.0. but mine is the ej25. Its definetely not the heat shields. I know that sound pretty well. Its a more solid sounding clank than that. Link to comment Share on other sites More sharing options...
subaru101 Posted July 14, 2009 Share Posted July 14, 2009 eventoday said: hello,I have an 01 outback with 214k on it. I have been noticing a metal sounding clank when i hit bigger bumps. Sounds like it is coming from under the the middle of the car. i have looked under the car but haven't noticed any missing bolts or anything that looks unsecure. I know this is kinda vague but any ideas? could it be anything to do with the transmission:slobber:? thanks jake could be the heat shields directly under the drivers area, i had the same problem, and wen i removed mine,the noise went away, could be worth a shot. Link to comment Share on other sites More sharing options...
tcspeer Posted July 14, 2009 Share Posted July 14, 2009 Check the big bushing at the back of the control arm, it is bolted up with two large bolts. It has a rubber bushing in it, if that bushing is leaking grease out that may be your problem. When these go bad you will also get a big clunk sound when you turn around on the highway. Also check your transmission mount. Link to comment Share on other sites More sharing options...
nipper Posted July 14, 2009 Share Posted July 14, 2009 Exhaust hanger? Does it happen at low speeds, higher speeds or all speeds? nipper Link to comment Share on other sites More sharing options...
