Assuming they are a 5X100 lug pattern, they will fit.
But I would stay away from them. The standard offset is +52mm I believe. The smaller you get, the more stress you put on the wheel bearings, and +35mm offset would be murder. If you get all 4 bearings replaced, then you can start with new ones. But if your car has higher miles, they might not last much longer with these wheels...
Sorry :(
