New hood scoop for top mount radiator
Bugaru
Nice - what's going on with that speedo there? Is that using an electronic sending unit or did you hook it into the stock cable?
I would really like to see some decent pics of your top-mount setup and how you shortened the front end.
I'm seriously thinking about going with a totally custom radiator setup. I would very much like to do stainless braided hoses and hydraulic fittings, etc.
Looks like an early 80s F-series speedo-
Is there a build thread on this?
There isn't really much build info on it. Although there should be :rolleyes:.
Without a doubt one of the top 5 EA series builds out there. Maybe someday he'll write more of it down and take more pics. He's (I think) still planning to be at the show and I'll try to get as many pics as I can when it's up here.
We used to run some of the trails in my area when it lived here but there's been much done to it since I last saw it. I'll let Ian fill us in on a complete list of the mods.....
Care to elaborate for the crowd man?
Ok so,
the speedo (80s F-150) actually plugs right into the cable from the ea81 trans. It's not exactly accurate, but I have long since lost the original soob speedo. After I get this thing on the road in the next few days I'll figure out how off it really is.
Rick, the gained entry angle is totally worth the hassle of moving the radiator up on top. You should be able to use a stock radiator, but I had to use a MR2 radiator due to clearence issues from the rollcage. Another nice thing about the top mount radiator is it dosen't get mud lodged in it when hitting the deep stuff.
Edited by Bugaru
Here are some of the mods I can remember-
Unhatched
4" Lift, adjustable in front by 3"
27" Super Swampers
Top mount radiator with dual Flex-a- Lite fans
Mad Max hood scoop
"Around the side" exhaust for more ground clearance
Dual Fuel, LPG/Gas
Bucket seats/5 point harnesses
21 point 1.5" DOM roll cage
Tube bumpers tied to cage
Tube skid plate frame tied to cage
Bed mounted fuel tank system, LPG or Gas
Custom tube dash/Steering Column
Power Steering
4 wheel disc brakes
Welded rear diff
Weber 32/36
Mostly new "waterproof" wiring and fuse boxes
All aftermarket gauges
"Waterproof" Alpine CD player with in dash 6x9's
On board air compressor
Built in trickle charger
Optima battery behind passenger seat
"Special" anti theft system and auto thief maiming device
Ham/CB radios
That's all I can think of for now. I'll get some good pics this weekend.
Ian
FYI I got her up to freeway speeds today and the scoop helped the engine keep cooler than ever. It used to get too hot at higher speeds because the air would go right on by the holes in the hood and the fans couldn't "grab" enough. Now it really rams it in there. I guessed on the size and shape and it seems to really work well, if anyone is interested in construction details, I could write it up with a printable template. No welding required. Cost less than $25.
The camber was so far out from the lift, I was burning up tires like nobody's business. I keep it dropped for the street and lift it when I'm putting in my rear axle for off road. Soon enough I wont need this setup anymore, I've got some mods in the works.
could this setup with the top mount radiator work with a 97 impreza.
Anything is possible - the stock hood scoop on your Imp. is not even half as big as it would need to be to divert enough air for the radiator.
With enough fabrication just about anything is possible. You could mount it on the roof if you wanted.
I didn't know what else to call it, but it's kinda up and around. I used 4" aluminum "C" channel for the front lift blocks so I could feed the exhaust tubing through it resulting in a gain of a few inches of ground clearance from where the exhaust used to run underneath.
Thanks.
The aluminum would break before bending, it's very rigid. Those are secondary supports to the cross member though, I have the skidplate tubing supporting most of it where it ties into the rollcage.
A few things I should mention about this radiator setup. The MR2 radiator does not have a radiator cap fitting, since it is a rear engine car the cap is within the engine compartment. It is inexpensive to have one welded on though, it only cost me $10. Also, I chose this radiator, like I said earlier, because it's the only one I could find that would fit above the strut brace on the cage. One could probably fit the stock radiator or possibly a larger one without a strut brace. The MR2 is a 1.6 and the rad has a little less fluid volume, but so far I haven't had any issues. Hoses line up well, brackets are easy to fab and they're plentiful. I may end up running a secondary Bluebird Bus heater core in the grill for that 110 deg weather you guys are having up there.
