mdjdc Posted July 17, 2009 Share Posted July 17, 2009 I have a 99 foreseter and yesterday I was trying to replace a half shaft. It is frozen in the hub. I sprayed some PB Blaster in there and I am going to give it a few days to see if it comes loose. If not, I am going to have to replace the knuckle. My question is what knuckles are compatible with the forester. Can I go to the JY and get a Legacy knuckle or do I have to find a Forester knuckle? Thanks Guys Link to comment Share on other sites More sharing options...
johnceggleston Posted July 17, 2009 Share Posted July 17, 2009 (edited) the hub assembly is universal as long as it matches your abs system, meaning i think a 92 legacy would work except for the abs sensor hole. these are rears, fronts crossover the same. item 2 or 3 here: http://opposedforces.com/parts/forester/us_s10/type_3/suspension_and_axle/rear_axle/illustration_1/ click on usage here: http://opposedforces.com/parts/info/28411AA000/ Edited July 17, 2009 by johnceggleston Link to comment Share on other sites More sharing options...
mdjdc Posted July 17, 2009 Author Share Posted July 17, 2009 Awesome. Thanks John Link to comment Share on other sites More sharing options...
idosubaru Posted July 17, 2009 Share Posted July 17, 2009 Legacy, forester, impreza hubs should interchange. I didn't get whether it was front or rear you're after but shouldn't much matter except I don't know much about the H6 stuff so you might want to avoid those. 2001 was when the change occured where ABS tone ring set up was different - being pressed onto the axle instead of in the hub like earlier stuff. So avoid 2001 and up for sure unless you want to "convert" which I doubt it. I've swapped a few front and rear EJ hubs, pretty sure they're just about all interchangeable as long as you have ABS like JCE said. Link to comment Share on other sites More sharing options...
mdjdc Posted July 17, 2009 Author Share Posted July 17, 2009 It is a front hub. I'm hoping that the PB Blaster will work. Link to comment Share on other sites More sharing options...
idosubaru Posted July 17, 2009 Share Posted July 17, 2009 You have a puller, if there's something to attach the arms to? Link to comment Share on other sites More sharing options...
mdjdc Posted July 17, 2009 Author Share Posted July 17, 2009 We puta puller on it yesterday and tightned it down with an air gun. Bent the bolt on the puller. I may try putting the hub in a press. Hopefully it won't break. Link to comment Share on other sites More sharing options...
