TRAVIS75 Posted July 23, 2009 Share Posted July 23, 2009 I am in need know of a clean pair of under wear and a wheel cylinder. Last night heading back into town, down a very steep grade and of course, it wasn't straight. Next thing i know, little pop and brake pedal to the floor, low brake fluid light comes on. Happy Happy Joy Joy. So I'm now trying to locate a wheel cylinder, which nobody in Podunk Town U.S.A. has, amazing since I know of at least 30 that are running around in our town alone. Back to the point, everyone is asking if its got 11/16 or 3/4 inch bore. I don't have the vehicle here to check, is there a way to narrow it down by application, perhaps better than the num nuts at our parts stores can? If not, can I just replace both wheel cylinders at the same time if I replace them both with matching bore sizes? For example, if mine are 11/16 bore and I order 2 with a 3/4 inch bore can I swap them both out? Quote Link to comment Share on other sites More sharing options...
zyewdall Posted July 23, 2009 Share Posted July 23, 2009 What kind of car do you have? Without that, WE can't narrow it down either :-p Quote Link to comment Share on other sites More sharing options...
TRAVIS75 Posted July 23, 2009 Author Share Posted July 23, 2009 Crap...I meant to put that in there, I imagine that would be extremely helpful. Its an 89 SW dl 4x4 d/r manual trans. 1.8. Also every store that looked it up only showed an Xt model or sedan, I would guess sedan must be the same as SW? Quote Link to comment Share on other sites More sharing options...
bratsrus1 Posted July 23, 2009 Share Posted July 23, 2009 Hey Travis This is Jerry, i have a 85 hatch 4x4 i am doing a rear disc swap over if the parts from it will make me an offer cheap or trade. Also need to know if it is right or left side of the car. Call me 1-509-952-2855 Thanks Jerry Quote Link to comment Share on other sites More sharing options...
TRAVIS75 Posted July 23, 2009 Author Share Posted July 23, 2009 Appreciate it, i can get the parts, they are available, I just need to know with out having car here if theres a way to tell if its got the 11/16 bore or 3/4 bore, and if they will interchange in pairs Quote Link to comment Share on other sites More sharing options...
Txakura Posted July 24, 2009 Share Posted July 24, 2009 the 4x4 wagon should have the 3/4" Quote Link to comment Share on other sites More sharing options...
zyewdall Posted July 24, 2009 Share Posted July 24, 2009 every store that looked it up only showed an Xt model or sedan Hmmm... Subaru made alot more than just the Xt and the Sedan in '89. There was also the wagon, hatch, coupe, and Justy, and maybe an RX and an XT6 too...... silly parts store I THINK that the 3/4" is for the EA82 (wagons, coupes and sedans) and the 11/16" is for the EA81 (brats, hatchs). But I am not 100% sure about that... Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted July 24, 2009 Share Posted July 24, 2009 NOTHING on a Subaru is SAE - 3/4" would be very near 19mm, but 11/16" doesn't have an even equivelent - it's 17.46mm.... I hate parts stores that do that - it's a METRIC car. I wouldn't guess that it wouldn't matter. The size difference is negligible - I would just go with the larger one's seeing as you have an EA82 and I beleive the drums are a bit larger than the EA81's. GD Quote Link to comment Share on other sites More sharing options...
Txakura Posted July 24, 2009 Share Posted July 24, 2009 the '3/4' are on the heavy vehicles; wagons, the 4x4's, and the turbo models '11/16' everybody except the justy (5/8") Quote Link to comment Share on other sites More sharing options...
TRAVIS75 Posted July 24, 2009 Author Share Posted July 24, 2009 Thanks guys, I had to make an educated guess yesterday afternoon, well semi educated, i never did graduate high school LOL. I found a parts store that was 45 miles away that had a set of the 3/4's so I sent her up to get them. I like the logic in the larger vehicle taking the 3/4 guess had I stayed in school I'd have figured that out :-\ Luckily after getting one off i found that it was 3/4. I was going to put the 3/4 on anyways to see what happened, it worked anyways. As far as them saying it was 11/16 or 3/4 i think alot of the time they do that because alot of there customers find it easier to measure in standard then metric. I work at a salvage yard and I know alot of times they will ask for the OD of something like a rotor and give you the options in MM's and it never fails, customer will call back give me the measurement, I'll send them the part, 3 days later they call back and measured their MM's wrong. Its just a thought. Quote Link to comment Share on other sites More sharing options...
