babyfacefitz Posted July 24, 2009 Share Posted July 24, 2009 I friend of mine has been told he needs a new cam shaft sensor. I will be doing his plugs and wires on the 98 obw. How hard is the cam shaft sensor replacment? thanks Michael Link to comment Share on other sites More sharing options...
davebugs Posted July 24, 2009 Share Posted July 24, 2009 Very easy. It's on the drivers side between the timing belt cover and beside the oil filler tube and the dipstick tube. Right there on top. Disconnect the connector and one bolt (8 or 10mm - I forget). Make sure they didn't say Crank shaft sensor. I little more difficult and sometimes they get corrosion in there pretty good. Link to comment Share on other sites More sharing options...
idosubaru Posted July 24, 2009 Share Posted July 24, 2009 Yah, really easy. One bolt, 10mm, replace sensor, done. Link to comment Share on other sites More sharing options...
OB99W Posted July 24, 2009 Share Posted July 24, 2009 babyfacefitz said: I friend of mine has been told he needs a new cam shaft sensor.[...] If the diagnosis was based solely on getting a P0340 (and possibly P0341) code, the problem could be the sensor, but just as easily might indicate a bad connection. You might want to check connector E15 (at the sensor) and connectors E1/B20 (6-pin at the rear of the engine, passenger side) for contamination. Link to comment Share on other sites More sharing options...
babyfacefitz Posted July 25, 2009 Author Share Posted July 25, 2009 Thanks Guys... How could the stealership charge $250 for the labor and $75 part? I know I stay away from them but for an easy part, how could they go all the way there? I guess it shouldn't surprise me. Link to comment Share on other sites More sharing options...
idosubaru Posted July 25, 2009 Share Posted July 25, 2009 that's how they roll. it's based on their book times, which probably say to remove stuff that doesn't need to be removed (and the mechanics wont' on a well known part like this). probably also charged diagnostic fees - read code, clear code, etc. might have been the crank sensor those prices were for - that takes 20 minutes instead of 10!!!! :lol::lol: Link to comment Share on other sites More sharing options...
